05-25-2016 08:44 PM
Sorry for the newbie question but I've searched Google and couldn't really understand this. I have a 40D with a 28-135mm EF lens. I understand this is a APS-C camera and since the lens is an EF that the effective zoom is 44-216mm. I would like to get more zoom but the EF-S telephoto is 55-250mm. 250mm doesn't seem like much more that 216mm and I'm not sure it's worth it. I've also looked at the EF 70-300mm which would be 112-480mm. It's twice as much money and would think I would want it slightly wider at the low end.
Also, if I go with the EF-S 55-250 would the STM be worth it over the standard? I want a quick focus as this will be used mainly for wildlife. How does the standard and STM compare to the USM of my current lens?
06-02-2016 10:18 AM
My 28-135mm IS USM kit lens doesn't do this and I leave IS turned on.
06-02-2016 10:27 AM - edited 06-02-2016 10:34 AM
@klavender wrote:My 28-135mm IS USM kit lens doesn't do this and I leave IS turned on.
That may not be significant. The IS mechanisms of the two lenses may work slightly differently.
BTW, I doubt that the 40D's viewfinder has 100% coverage. It may be that what your lens sees isn't changing when you press the button, but rather just the exact portion of the view that's presented to you. But even in that case, it's probably the IS mechanism that's causing it. It may be that the behavior you're seeing is perfectly normal for that camera/lens combination.
06-02-2016 10:30 AM
06-02-2016 10:45 AM
Another factor could be the camera's AF mode, One Shot or AI Servo. Test the lens in "One Shot" mode, and only the center AF point active. I have had a lens where Optical Stabilization could cause the image to "shift" if the camera where trying to track a subject in AI Servo mode....Sigma 150-500mm did that. OS and AF would get into a tug of war, it would seem.
06-02-2016 10:49 AM
06-02-2016 11:22 AM
@klavender wrote:
I'm 99% sure I have it set on One Shot and 100% sure I only have the center AF point active. But it is something I will double check tonight. Thank you!
Good. The only purpose that lens Image Stablization serves when your camera is on a tripod is to put an extra drain on your battery.
06-02-2016 06:49 PM
I had the camera set on AI Focus. Changed it to One Shot, no change. Turned off IS, success! It doesn't move with IS off. Even with it on, it's only a slight shift. Just very weird. Haha.
06-03-2016 06:37 PM
"I noticed something strange about my refurb. 55-250mm lens I just bought."
It is the IS. It is also most likely why the lens was returned and is in the refurb store. If I were you, I would return it tomorrow. It may be in spec so Canon will not fix it more.
BTW, no Canon lens I know of turns the IS off when attached to a tripod. Certainly none of the consumer lenses. Plus I have never seen it hurt to leave it on. The IS is way better than it used to be and perhaps there was a time that was true. I almost never turn it off.
06-03-2016 08:49 PM
@ebiggs1 wrote:"I noticed something strange about my refurb. 55-250mm lens I just bought."
That is simply how that lens behaves. It doesn't have the smarts to shut down IS when it is on a tripod. As long as the camera is "awake" the IS keeps trying to adjust itself. The lens doesn't seem to know when the AF is active in the camera, and when it is not....in other words, knowing when the shutter button is being pressed, or not.
I say leave the IS off when using a tripod. It is only a drain on the battery when mounted on a tripod.
06-03-2016 09:06 PM - edited 06-03-2016 09:10 PM
There seems to be some misconception regarding Canon IS...per Canon's writeup, for certain lenses, especially older ones, leaving IS on when mounted on tripod is detrimental to sharpness...Here is an excerpt:
Using IS with a tripod
When using certain early models of IS lenses with a tripod it was necessary to turn off the IS function. This is because of a phenomenon known as ‘Shake Return’. Shake Return occurs when the IS system tries to correct vibrations to which the system itself contributes. When the IS lens sits on a tripod, the IS detection gyros pick up any tiny vibrations or movement; these might be caused by the tripod being knocked, or the photographer adjusting a camera setting.
The IS system then swings into action to correct that movement. The movement of the IS lens group causes its own minute vibration, which is in turn detected by the movement sensor, which triggers another correction. This ‘feedback loop’ can continue endlessly, resulting in the addition of unwanted blur to images that would be sharper if the IS function was switched off.
Link to whole article: http://cpn.canon-europe.com/content/education/technical/image_stabilization_lenses.do
Tamron lenses with Canon mount has warning in bold in their manual to turn VR (their version of IS) off. I tried to leave it on using my Tamron 150-600mm lens and IQ was noticeably worse with VR on while mounted on a tripod. When in doubt, turn IS off.
