05-28-2016 01:51 PM
I currently own the EF 70-200 f/2.8L IS II USM lens and am considering purchasing the EF 100-400 f/4.5-5.6L IS USM lens for an upcoming African safari trip. Curious to opinions on whether I would be better off buying the EF 2.0X III extender and using it on the 70-200 f/2.8 lens than buying the 100-400? I have never used an extender, but it would seem from the specs that all I would be giving up on are the low light / longer focal length circumstances - while having the convenience of using a single lens for almost all circumstances and saving almost $1,500...
05-28-2016 06:56 PM
Thanks to all for thoughts...still doing my homework, but leaning towards new 80D and the Tamron 150-600.
05-28-2016 03:09 PM - edited 05-28-2016 03:12 PM
You lose 2 stops of light with the 2.0x extender, but it also hurts your image quality.
This is is one of those questions that will elicit a lot of subjective answers and maybe some strong opinions, but little real help unless you can see with your own eyes.
Go go to The Digital Picture website, look in the "tools" section for "lens comparisons". You can see the 70-200 with a 2x extender side by side with the 100-400 lens. Make sure you have the same aperture on both lenses to be fair. You can see center, off center and edges, and you can select different focal lengths.
Judge for yourself, but the IQ hickey with the 2x extender is worse than for the 1.4x extender and you may find it unacceptable. Or you may not.
05-28-2016 03:51 PM
If you don't see a use for the 100-400 after the safari why not rent one?
05-28-2016 03:54 PM
@jrhoffman75 wrote:If you don't see a use for the 100-400 after the safari why not rent one?
A great point.
And and as long as you are renting not buying, you could go grander than the limits of your purchase budget. Like the 200-400 with 1.4 teleconverter built in, or even like a 500mm f/4?
05-28-2016 03:59 PM
To my eye, the 2.0 TC on the 70-200 is a lot less shap than the 100-400 across the whole frame, but especially in the corners. The TC also adds a lot of chromatic aberration/ purple fringing.
05-28-2016 04:03 PM
celson.
This would not even be a consideration for me. There is no way I would use a 2x on any lens. Even the best 70-200mm in the world as the Canon is. It is a shame to hamstring such a great lens with a tele converter. However, I will freely admit the 1.4 extender does work really well with the Canon EF 70-200mm f/2.8L IS II USM Lens. I don't use that combo a lot but when I do it is OK. Some lenses get along fine with the 1.4x but, IMHO, not the 2x.
Just how many "upcoming African safari trip(s)" do you plan or take. One? Why jeopardise it with anything less then the best you can afford? Besides you can sell the 100-400mm when you return and are though with it. Right?
But if I were you there are a couple different options I would consider. One is the ef 400mm f5.6L prime lens. It is better than the zoom you are considering. Or if you think IS is a must factor the ef 300mm f4L IS with the 1.4x tele converter. It would give you a 420mm rig @ f5.6 with IS. Plus you would have a much better IQ lens for when 400+mm isn't needed. The 300mm is extremely sharp. I just love that lens.
Current new prides;
Canon EF 100-400mm f/4.5-5.6L IS II USM Lens... $2100
Canon EF 300mm f/4L IS USM Lens... $1350
Canon EF 400mm f/5.6L USM Lens... $1150
Canon Extender EF 1.4X III... $425
Prices are off the top of my heard but I believe they are pretty close. There might be rebates I don't know about. There is always used sources and the Canon refurb store.
What camera do you have? If I was going with your circumstances I would take my Canon EF 70-200mm f/2.8L IS II USM Lens. My Canon EF 300mm f/4L IS USM Lens with the Canon Extender EF 1.4X III.
Now that is just me. What do you say? ![]()
05-28-2016 04:10 PM - edited 05-28-2016 04:10 PM
"... why not rent one?"
Renting is certainly an option but make sure you take out the insurance if you do. It isn't the same as when you rent and remain in the US. Renting can be very expensive and all you have to show for it is a nice pink receipt. ![]()
Buying one and selling it afterward even at a loss is probably a cheaper way to go. White lenses re-sell easily and good.
05-28-2016 04:14 PM
Thanks Scott. I forgot to mention...using an older body, 40D. Will autofocus work at all using the extender? Just work more slowly?
05-28-2016 04:23 PM
Great thought John...thank you! I will look into that, but inclined to buy as I travel a fair bit and also shoot my kids sports
05-28-2016 04:30 PM
Thanks for the suggestions.! So your thought would be to go with the 300 + 1.4x TC rather than the 100-400 zoom? Both would give me ~400 at 5.6 as you say...but how do you think image quality would compare at 400 focal length between the two? I like the thought of the 400 prime, but I DO think the IS is necessary, which throws me back to the option of the 300 prime + 1.4x TC.
