yellow will not print
jgw0
I have an ip4920 printer.  The color yellow will not print.  The cartridge has ink in it and the breathing hole is clear.  I have taken the print head out and cleaned it.  I can force ink through the yellow to the printhead.  I have cleaned it and done 2 deep cleanings (colors) - all to no avail.
thoughts?
25 REPLIES 25
Hi Bill S - Sorry for the delayed reply, Summer distractions and just busy.
First, sorry if this comes off flippant, but I'm an adult that grew up with computers and their peripherals and we live in 2018. Of course I already did anything you'd suggest that involves "user manual trouble shooting." Second, I'd bet that every user that has commented here has tried every fix as per the user manual. Third, it being 2018 and being somewhat tech saavvy is a requirement to function in the Western world, we all probably looked up DIY fix-it videos etc.. So, please offer solutions not more of the same...
Especially when this thread makes it obvious this is a printer issue that goes beyond OEM or non-OEM cartridge use and more than likely has nothing to do with a ink route being clogged.  As far as I can tell you and Canon have not addressed this and due to the way the broken world now works, most of us will trash our printer and buy a new one because it'll be cheaper than any repair route. Lame and forsakes our environement and future generations.
Make me realize I'm wrong or give me a better answer please.
Ok, just so everyone knows.
Water + Yellow ink will clog the print head. So cleaing your pritner head with water might last a few prints until you get the same issue.
I don't recommend you doing head cleans to de clog you can go through tons of ink and if you use genuine cartridges it's going to cost you a fortune! What you need to do is the following:
Open the latch to see your cartridges. Remove all cartridges and keep them safe this will take a while. Push the holder slightly to the right and pull the bar outwards this allows you to remove the printer head. remember how you removed it so it's easier to put back in.
Now you want to clean up the head at first you can use water windex etc. Just make sure its not pushing ink out anymore. You can use shringes to blow water through to test this from the top pads. I have done this multiple times but would only recommend this if you have tried everything else.
Once you have done this you will need an alchohol solution to flush any stuck bits cartridge refil kits come with a cleaning solution that i use. Leave it to soak on paper towel for 20 minutes or so. Then flush again with alcohol solution this is because you don't want water in the system because  as mention yellow does not like it. One more step is to add pressure to the pads at the top with a paper towel this got some of the stuck colourant out for me but it might have just been luck. Too much pressure would most likely brake it or warp it but what you got to lose if your spending $30+ on ink... Once everything is dry put it all back together again and test.
It should now work if there is no yellow all after all that your print head is dead electric contacts perhaps. Oh and always Replace the printer not the head unless of course the head is a fraction of the price. The head is normally the price of the printer like the case is for the ip7250.
I print a shed load of cards and such and yellow is always the one that goes funny... alot of time wasted with that one.
Good luck.
Follow-up to previous post.  I'd been balancing new print head vs new printer tradeoff.  But decided first to make an assumption that it was an ink clogging problem and do all I could with the existing print head.
Tried declogging it with IPA but this made things worse - now no printing on cyan or black either.  Then, after that particular horse had bolted, found a web post 'did alcohol damage my printhead?' which had a reply saying 'not recommended'.  The reply continued with the poster's own print head cleaning recipe.  I thought I'd give it one last go and followed the instructions as closely as I could.  And this worked.  I've been printing for 2 weeks now with the cleaned-up head and all good so far.
No promises it'll work for anyone else - they're complicated things and probably have numerous failure modes.  Good luck.
- Peter
PS in my web trawling there had been unanimous agreement that you should not run your ink tanks dry. I had done just that and it was probably the cause of my original problem.
Re: not letting ink tanks run dry.  Thanks for this, though it is a little frustrating since my Canon printer, MX 870, always says they're empty when they are still working.
Any thoughts?
Perhaps my suggestion will help someone coming across this thread. I only have Canon 4920 printers, not some of the other models mentioned here, but I suspect we all have similar issues possibly with similar solutions.
My yellow was not printing correctly. Head cleaning would sometimes clear it for a short while, then it clogged again. This showed up as a “smear” of white (non-printing area) in the yellow bar of a test print. My last 4920 printer did this as well late in its life and I finally threw it out, purchasing another one on an auction site since Canon no longer sells this excellent, inexpensive, compact, 2-tray printer (envelopes or labels in top tray, paper in the bottom tray, YAHOO! There’s nothing like it now except the bulky awkward unreliable MB2320.)
This time I was more determined to fix it especially since I’ve only been using this printer a few months (but no warranty on it). Repeated cleanings and “deep cleanings” were not working. I finally learned from YouTube how to remove the print head. This is simple, anyone can do it. Just pretend you’re adding ink (which moves the cartridge holder into position) unplug the printer for safety (and to possibly avoid shorting the printer head), lift the bar in front, and reach in to remove the head.
I tried soaking the bottom of the head in a shallow tray of Windex. I tried using some “ink dissolving” fluids from my Epson printer setup. I put the head back in but no luck, yellow still clogged. Other heads also clogged during the Windex process, but they cleared up again with normal cleanings.
I had another “new” 4920 on the shelf as a backup for this one (did I say how much I like this little printer?) so finally, to determine if I really had a head problem or not, I took out the head from the new printer and put it in the old printer. It worked fine right off the bat, perfect test print. So I figured I’d buy a new head from an auction site. Canon heads are about $95. there right now, with Chinese knockoffs running much less, I no idea if they work though. I figured I’d put the replacement head in the new printer, ready for use when the old printer finally dies.
With nothing to lose now on the old printer head, I got more aggressive. There are videos of people running warm water over the print head, using a garden hose, etc. to clean it. But on my Epson printer (another story) I’d learned you could use a syringe to force cleaning solution (or Windex) through the head and this seemed like something to try on the Canon. I located some tubing which just fit over the connector which the cartridge seats upon. In one video I saw that a guy used a forceps to remove a small rubber seal around this connector (in the print head, this is, just below where the cartridge lets out ink. One rubber seal for each ink color but you only need to pull the one you’re trying to clear). I pulled out the rubber seal, it comes out easy but try not to damage it with a sharp tool. (AND NOTE how it came out so you can put it back in correctly). I stuck the rubber tubing over the connector, with the other tubing end already connected to a syringe. Filled the syringe with Windex and pressed down. It’ll escape around the connector as you press, but you should also see ink and fluid coming out the bottom of the print head (hold it over some paper towels to monitor progress). I tried to hold the print head in such a way that no fluid got on the electric contacts on the back of the print head. I repeated this process maybe 5 times, until no ink color (yellow) came out of the print head onto the paper towel beneath, only Windex. It’s a mess, wear rubber gloves.
Dry the print head with paper towels. If you got it soaking wet, let it sit a while under a warm lamp or the like. I am not sure what happens if the electrical contacts have fluids on them when you reinsert the head into the printer.
So now I removed the “new” print head I’d been using since stealing it from the new printer, and put the old print head back in the old machine. First test print: not good. Ran a cleaning cycle: next test print: perfect! I’ve made a few prints since this event earlier today and much to my surprise believe I’ve cleared the problem. If It re-occurs, I’ll put in the “new” print head again and buy another print head on the auction site as a backup and to use in the new printer when/if needed.
Sorry I don’t have photos to offer, (I'll try to a photo of the syringe...use 2 hands and wear gloves!)Screen Shot 2019-09-07 at 4.35.25 PM.jpg
Again, just find a small syringe, some rubber tubing (hardware store) that will stretch or fit over the print head ink inlet, and press down firmly on the tubing as you push down on the syringe, trying to force most of the Windex down into the print head. Do it slowly and gradually. Slowly and gradually. It may take some practice to get it through there.  The tubing I used is black rubber, 1/4 inch outside diameter, and 3/16 inside diameter. Again it was not a perfect fit but I could get sort of a seal and force the Windex through the print head. Best of luck.
Avatar
