09-11-2020 12:40 PM
hello to all! I am trying to connect my computer (windows 10) to a mg6620 wiressly but the printer is not found on the add a printer list. not sure what I did wrong and how to correct that! thank you for the help!
10-13-2020 01:27 PM
Hi fnglover,
First, let's connect your PIXMA MG6620 to your wireless network:
1. Please press the HOME button on your PIXMA MG6620.
2. Swipe the LCD screen and tap WLAN
3. Select Wireless LAN Setup
4. Select Standard Setup and press OK. If that does not appear, please select "To other connection methods" and then Standard setup
5. Select your wireless network form the list that appears
6. Please enter your wireless network password.
Once "Connected" appears, please press OK
Next , we will uninstall and reinstall the driver on your computer. To do this, please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon MG6600 series and left click on Remove device. Repeat until all MG6600's are removed.
5. In the upper left corner, click on Control Panel (or the Back button).
6. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
7. Click once on "Canon MG6600 series MP Drivers" and then click Uninstall at the top.
8. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
9. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
2. Click the Select button next to "MG6600 series MP Drivers Ver. 1.01".
3. Click the Download button. The drivers will download.
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click "mp68-win-mg6600-1_01-ejs.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
Once the installation has completed, please attempt to print.
