12-04-2012 07:12 PM
what is error 5100 for multifunction printeers and how do you fix it?
01-20-2017 12:42 AM
My printer reads support code 1500. I had a paper jam when I received this code. I removed the paper that was jammed in the printer. I have turned off my printer off 10 times, cancelled the printing orders that was pending when I recieved this code. It is giving me Support code 1500 and gives me 3 steps. I did remove the paper that was jammed, I ensured that there was no objects jammed into the printer and turned it off several times.
I have used a flaslight to ensure that there is no objects jammed in on both sides. I load the paper into the tray and turn on the printer. The printer makes a weird sound and the support code 1500 will not go away no matter how many times I turn it on and off.
All I currently, know at the moment is that my print is a Canon and I am using ink cartridges 251 XL. I am currently at work and not able to provide the model number of the printer. I am done my shift at 5:45 am and will be home around 6 - 6:30 am if you require further information.
Can you help me to get rid of the code?
01-20-2017 12:38 PM
Hi Gumba3,
We can assist you with clearing the 1500 error, but we would need to know the model number of your Canon printer.
Once we know this, we can assist you further.
01-21-2017 06:36 AM
My printer is Canon Pixma 5520
01-21-2017 10:38 AM
Hi Gumba3!
For an Error Code 5100, follow the steps below:
01-22-2017 12:11 AM
I did try those steps and I was still getting that signal. Thank you for help. I appreciate your help. When I got home and attempted to use my scanner. The issue resolved itself. I am able to print without having any error codes.
01-21-2017 06:33 AM
It is a Canon Pixma 5520
02-19-2017 04:53 PM
@WarrenSmith wrote:what is error 5100 for multifunction printeers and how do you fix it?
05-02-2017 09:45 PM
05-02-2017 09:52 PM
Hi, SherryAK!
Please try the steps found by clicking HERE.
If the issue persists, please reach out to our support team via Email at http://Canon.us/SupportCF
Thanks!
01-26-2018 08:06 PM
I am just setting up my mx922 printer and i get an error code 5100. I havent figured out what is wrong.
