01-22-2020 07:16 PM
I have a Samsung Note 10+ and i was able to print at one time and now all of a suden i cannot print. message im getting is that "cannot communicate with the printer is enabled on your smartphone. do you want to disable"
01-22-2020 07:29 PM
Hi, angiepl1!
So that the Community can help you better, we need to know which Canon printer model you own.
Your Canon printer's model number should be displayed prominently on the top and/or front of the unit. Our model numbers typically begin with 2 or 3 letters (such as TS, TR, MX, MG, MB, MF, MP, LBP, iP, or iX) followed by up to 4 numbers.
Thanks and have a great day!
01-22-2020 07:31 PM
TR4500
01-24-2020 01:34 PM
Hi angiepl1,
Please try reconnecting your PIXMA TR4520 to your wireless network:
1. Press wrench and screwdriver button on your PIXMA TR4520
2. Use the arrow keys to select Wi-Fi setup and press OK
3. Use the arrow keys to select Manual connect and press OK
4. If a WPS message appears, press the STOP button
5. Using the arrow keys, select your home wireless network's name and press OK
6. Enter the password and press OK. To switch between lower case, upper case and numbers, press the * key. To delete a character, press the left arrow so the cursor is under the character you wish to delete and press the BACK button
Once connected, please attempt to print from your phone.
