08-12-2017 08:56 PM
my printer is working fine and prints stuff sent from my windows 10 computer. However, just today, I tried to copy a page on the flatbed, and it didn't print a thing. I did a preview function and the doc was there, but the printout then yielded a blank page. is there some setting that is off? One of the print tanks was empty and I replaced that. Nothing else seems wrong. What to do. I would like to copy some documents..help help!
08-18-2017 02:37 PM
Hi, mzpurple!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
08-19-2017 04:33 AM
Hi mzpurple
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-221M
CLI-221BK
CLI-221GY
PGI-220PGBK
CLI-221C
CLI-221Y
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MP990 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Settings and press <OK>.
3. Press <OK> on Maintenance.
4. Press <OK> on Nozzle Check Pattern.
5. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to this email. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
4. Press <OK> on Cleaning.
After a few cleanings, please print another Nozzle Check.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
