11-28-2019 10:12 AM
Hello,
Subject says it all. Whether from panel or through Windows 10 or through macOS10.14 produces the black bar running vertically through the scanned document. Copying does not produce this black bar. I have updated the software, drivers, etc. in both operating systems. I have reset the printer back to factory defaults. This just started about a month ago. Really like the quality of printing photos and documents. This only being over a year old should and rarely used is unacceptable.
Any help that can be provided is much appreciated.
Take care,
Frank
11-29-2019 02:55 PM - edited 11-29-2019 03:00 PM
Hi Frank_G.
Try wiping down the printer's scanning bed; if the protective plastic film hasn't been removed, pull it off.
From your description, more likely than not, you may need to call in for support, and arrange for the printer to be replaced. If the TS9120 was purchased in the U.S., phone-based support is available at 1-800 OK CANON (1-800-652-2666) 8 am to 8 pm Eastern Time, Monday through Friday (excluding holidays). If you're outside of the U.S., you may find your local branch of Canon and its contact information through the Canon Global map.
Update: Upon further review of your comment, you mention that the bar does not occur when copying. Were you making color copies, or black and white copies? If you made a black and white copy, try instead making a color copy to see if it produces the same black strip. If the black line does not appear on either black and white or color copies, then the problem is more likely to be either in a low connection between the printer and computer, or in software used on the computer. Let me know what program you're using to scan, and provide an example of the black vertical bar through the scan results.
12-01-2019 09:30 AM
Hello Darius
Thanks for the suggestions.
I tried copying and scanning in both black and white and color, pdf or jpg. Same results. Copying no issues. Scanning black bar.
Software Win10(x64) - Canon IJ Scan Utility 1.4.0.16 from file mpnp-win-TS9100-1_02-ea34_2.exe
Software MacOS 10.14 - Canon IJ Scan Utility 3.2.1
Signal Strength of Wifi - 80%
Link Quality - 90%
Current firmware up to date - V1.130oE-o-I3a
Scanned document results:
Thanks,
Frank
12-04-2019 01:49 PM - edited 12-04-2019 01:51 PM
Hello Frank_G.
Thank you for the example. It looks like the data is being cut-off mid-scan. This might be caused by security software on the computer, or restrictions on the router. As a test, load something on the platen. On the Windows 10 computer, open the IJ Scan Utility, then click on ScanGear. In ScanGear, click on Preview. Does the black bar appear there?
With the same original, on the Mac OS computer, open Image Capture (found in the Applications folder). Ensure the "TS9100 series" is selected, then scan or preview the image.
Does the preview on Winodws 10 have the black bar? Does the Image Capture show the same black bar?
Edit: Also, if possible, try scanning through a USB cord to each computer, and let me know if the USB connection experiences the same problem.
I look forward to your response.
12-07-2019 08:08 AM
Hello Darius,
Thanks for the help. Sorry for such a long delay. I have been traveling for the past couple of months.
Windows 10 preview displays the exact same results.
MacOS Image Capture displays the exact same results.
USB displays the exact same results.
Do I have to call to see if I can get some sort of reimbursement?
Take care,
Frank
03-18-2020 03:03 PM
Hi Frank_G,
It is recommended that you contact one of Canon's Technical Support Representatives via phone. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
