01-10-2013 09:10 PM
I can't print because it says "a communication error has occurred"
01-11-2013 11:54 AM
Hi nilstrom! In order for our Community and Subject Matter Experts to assist you better, we'll need to know which product you're using, as well as the version of Windows/Mac in use. Also, if you have any other information you feel that's helpful, feel free to share!
01-12-2013 02:04 PM
My computer is a Dell Inspiron 530. When I try to print (Canon MP210) I get this signal that says "cannot print with current printer set up." It is the same setup that has been used since it was first installed and worked great for a number of years. Now...My pc will not allow me to get into the control panel. it flashes but will not open. I think if I could get into that I could print a test copy and it would work again as in time past. How can I get my control panel to open.
01-13-2013 08:49 AM
Hello ebeatty.
Unfortunately, we are not familiar with the error that you have described.
Please try printing from other programs to narrow down the cause of the error.
If the Control Panel will not open from your Desktop or Start Menu, we would have to advise that you contact your computer manufacturer to resolve this particular issue.
03-24-2013 08:24 AM - edited 03-24-2013 08:25 AM
I have the same problem when trying to print.
MacBook Pro
OSX 10.8.3
MG 5420
My printer is connected by WIFI and I can open up the utility and check ink levels and run maintenance on the ink jets?
When I try to print it says Printing and trys to print then comes the "Communications Error".
I can also print from my IPhone 5 using AirPrint which proves the printer is connected to the WIFI network.
