08-05-2014 10:11 PM
I have unplugged and replugged scanner, restarted computer, uninstalled and re-installed driver and same result: documents are all-black. The lamp on the scanner appears to be working. It is bright when scanning.
08-05-2014 10:26 PM
Hi, SDeGroff!
So that the Community can help you better, we will need to know exactly which operating system is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
08-13-2014 09:59 AM
I am using Windows 7 Pro; 64 bit
08-25-2014 11:11 AM
Hi SDeGroff,
Performing a few calibrations should clear up the issue that you are experiencing. Please follow these steps to perform a calibration:
1. Click the [Start] menu and select [(All) Programs], [Canon], [CanoScan Toolbox] and then [CanoScan Toolbox].
2. Click the SAVE.
3. Place a checkmark in "Use the Scanner Driver to Make Advanced Settings".
4. Click Apply.
5. Click Scan.
6. When Scangear appears, click the Settings tab at the top right side.
7. Click the Calibration button.
Perform 3 or 4 calibrations and then attempt to scan again.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
