08-23-2015 06:40 PM
I just got a PIXMA ip2820 and it did not come with all the cables required to connect to my pc or is it wireliss and if so how to I get it to connect wirelessly
07-18-2018 10:02 AM
Mine also did not appear to come with all the cables that were needed, however unlike the others, the box itself states that the USB cable is included but it was not, this clearly is false advertisement and needs to be looked into as that's not something that should be happening
08-12-2018 10:40 AM
08-12-2018 10:42 AM
08-20-2018 10:00 AM
You have made a BIG mistake by not supplying a cable. It is massively annoying and inconvenient to get home and not be able to use your printer. It's a rip off to make people buy a new cable on top of the purchase for their printer. Imagine buying a kettle and getting home but you can't have a cup of tea because you must first order a cable.
08-20-2018 10:01 AM
What a lot of rubbish, it's just a racket and it's a great way to annoy your customers. Well done
09-08-2018 07:54 PM
Honestly this is complete B.S. im a student and i do not have the time and money to be running back to the store. I found it very inconvenient that i thought my computer wasnt recognizing my printer only to find out i need a usb connector to connect it to my computer and one isnt even supplied with it.
10-21-2018 05:12 AM
11-02-2018 05:14 PM
By the logic of "you're probably replacing an old printer that died prematurely so don't need another USB cable" or "you might need a longer cable than we would supply" why do they supply power cables of a standard length ?
It's annoying as hell and realistcally, the cost to supply a USB cable with each printer is negligible, it could be written off and forgotten about
11-06-2018 12:29 PM
I'm not goint to waste too much of my time here becasue I am headed to return the last Canon product I will ever buy.
No cable. Box doesn't say that ANYWHERE. Pathetic.
11-21-2018 04:26 PM
I just dropped by to say that I'm also returning my MG2550S and getting the HP that was in the store instead.
Also, I was planning to change my Canon 450D with a 200D but will opt for a different brand that sells fully equipped gear.
