05-08-2013 02:51 PM
05-12-2013 05:07 PM
Hello helonwheels1.
First, a test of the printer should be performed. Print a Nozzle Check Pattern to confirm whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned. Please follow these steps to do so:
1. Press the <COPY> button.
2. Press the <MENU> button.
3. Press left or right arrow key to select [MAINTENANCE/SETTINGS].
4. Press <OK>.
5. [MAINTENANCE] will appear.
6. Press <OK>.
7. [NOZZLE CHECK] will be highlighted.
8. Press <OK>.
9. [YES] will be selected.
10. Press <OK>. The Nozzle Check Pattern will print. Please compare your printout with the example that has been attached to this message. If lines are broken or white lines are present, clean the print head.
To clean the print head, please follow these steps:
4. Press <OK>.
6. Press <OK>.
7. Use the down arrow to select [DEEP CLEANING].
8. Press <OK>.
10. Press <OK>. The printer will perform a printhead cleaning. The print head cleaning takes approximately 30 seconds to complete.
11. Print another Nozzle Check Pattern to see if the print quality is improved.
If these troubleshooting steps do not work, feel free to call us at 1-800-OKCANON.
05-13-2013 03:22 PM
This did not solve the problem. Any other suggestions?
05-14-2013 04:40 PM
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the link below for additional assistance.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
