04-21-2015 12:20 AM
Hello - my printer prints and copies fine, but when I try to scan to my pc, it just says processing and then returns to the main screen without any movement of the scanner. I am using Windows 8.
07-15-2015 11:39 AM
Has this not been answered? I have the exact same problem.
07-15-2015 11:51 AM
Hi LCaulkins,
Are you also using Windows 8?
Are you using your PIXMA MX922 with a USB cable or are you using your PIXMA MX922 wirelessly?
07-15-2015 12:05 PM
I'm using it wirelessy. It prints without any problem from this computer through that mode.
07-15-2015 12:19 PM
Hi LCaulkins,
Uninstalling the network port and printer driver and reinstalling them will resolve this issue. To do this, please follow these steps:
1. Put the PIXMA MX922's CDROM in the CDROM drive. If the welcome screen appears, exit it.
2. Place the cursor in the upper right hand corner of your screen to display the Charms Menu.
3. Click on Search.
4. Type RUN.
5. In the Search Results, click APPS and then click RUN in the results to the left.
6. Click Browse. In the Browse window, click on "Computer".
7. Double click the CANON_IJ CDROM.
8. Double click the folder named WIN.
9. Double click the folder named Driver.
10. Double click the folder named DrvSetup.
11. Double click the file named DELDRV. If you are using the 64 bit version of Windows, double click DELDRV64.
12. In the Run box click OK and follow the on-screen prompts to remove the driver.
Once complete, please follow these steps:
1. Place the cursor in the upper right hand corner of your screen to display the Charms Menu.
2. Click on Search.
3. Type RUN.
4. In the Search Results, click APPS and then click RUN in the results to the left.
5. Click Browse. In the Browse window, click on "Computer".
6. Double click the CANON_IJ CDROM.
7. Double click the folder named WIN.
8. Double click the folder named Driver.
9. Double click the folder named LAN.
10. Double click the file named CNMNPU.exe
11. In the Run box click OK.
12. Follow the prompts to uninstall.
Once complete, restart the computer.
To install the unit for use over your network wirelessly, please follow these steps when the computer restarts:
1. Press the <Menu> button on your PIXMA MX922.
2. Select Setup and press the <OK> button.
3. Select Device settings and press <OK>.
4. Select LAN settings and press <OK>.
5. Select Wireless LAN setup and press <OK>.
6. Select Other setup and press <OK>.
7. Select Advanced setup and press <OK>.
8. Follow the on screen prompts to complete the setup.
Next, please download the latest driver for your PIXMA MX922:
1. Visit Canon's website at: http://www.usa.canon.com/cusa/support/consumer
2. Type PIXMA MX922 in the "Enter Your Model Name" box and click GO.
3. On the Support page for your unit, click the 'Drivers & Software' link in the middle of the page.
4. Under Recommended Downloads, please click on the MX920 Mini Master Setup.
5. If you agree, please select the checkbox next to "I have read and agree to the terms of the Disclaimer and wish to
continue with the download".
6. Click on the Download button.
7. A File Download box should appear. When it does, select Save.
8. When the Save As box comes up, close all windows.
9. Once the download is complete, open the Downloads folder.
10. Double click the [mast-win-mx920-1_0-ucd.exe] file.
Files will extract. Follow the prompts and the installation will complete.
Once reinstalled, please attempt to scan.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
07-16-2015 07:56 PM
04-09-2016 01:56 AM - edited 04-09-2016 01:59 AM
I hope this will be of help (and works) for anyone with this issue when attempting to scan wirelessly. I think this will also solve my Google Print issue (it would drop and I'd try everything, and somethings re-init on the print cloud would work, but mostly not).
I could print as well (win7, latest mx900series drivers,etc etc). I always attempted to address the issue on the printer's OSD menu or within the printer properties of windows. here is my solution:
Now you will be able to scan.
[edit] unfortunately this does not resolve the google cloud print (printer is unable to connect to canon/google's server to print the auth url)
-joe
09-21-2016 10:55 PM
01-16-2017 09:08 AM
I am having the same issue and was going to try your directions, but unfortunately, I cannot find the CDROM. Is there a download for it?
Thank you.
03-02-2017 03:14 AM
Hi Patrick, I've reinstalled as you say, and now the problem is back. Can only scan from IJ Scan Utility, no action or error message if I try to scan from the printer. I can't keep reinstalling every couple months. What now?
