mp830
mags
I keep receiving an error on the screen of my mp830 that says:  Install the correct print head. This started since I put in new ink in all but one ink well...which is the number 5 one, the biggest one in size.  What do I need to do so I can print.
mags.
2 REPLIES 2
Karl1
Rising Star
Hi Mags,
I recommend trying to reseat the print head to resolve the issue.  Use the following steps to reseat the print head:
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10.   Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
  11.   Close the inner cover and the scanning unit (printer cover).
If the issue persists, I recommend using the Contact Us link to contact our support staff who can provide applicable service options.
Maryruthmarks
I had the same print head problem. How did you resolve yours?
Mary Ruth
