installing pixma mx850 on a windows 8 machine
MelissaOrange
I'm installing a PIXMA MX850 onto a laptop with Windows 8. Installation disk doesn't work. I've downloaded the drivers and software, but I need to know how to do the installation - e.g. which file do I run first? NON-techie here. Thanks.
11 REPLIES 11
katerobinette16,
Double check to make sure that the USB cable is connected to the correct port on the back of the MX850.  It is possible to conenct a USB cable into the phone jacks or ethernet port if seated just right.
If you continue to have difficulties, find more help at Contact Us.
First, you should know what version of windows 8 is your computer. Pls check this relative video:
https://www.youtube.com/watch?v=M6h0DqZW9-E
Once you already know the windows 8 version, use this information to select the correct printer driver to install in your computer. Use the installation DVD / CD and follow the instructions carefully.
Happiness for your Printer
Friends and Family
