10-06-2013 08:39 PM
Is anyone having issues with the i9900 not getting the colors right when printing from adobe or web pages?
10-10-2013 04:59 PM
Hello sbstooger.
We would like to perform a few tests to ensure that the printer is working correctly.
First, please make sure that the installed ink tanks are correct and full of ink. The correct order is:
BCI-6PM Photo Magenta
BCI-6R Red
BCI-6BK Black
BCI-6G Green
BCI-6PC Photo Cyan
BCI-6C Cyan
BCI-6M Magenta
BCI-6Y Yellow
Next, a test of the printer should be performed. The Nozzle Check pattern shows if each print head nozzle is operating properly. Please perform the following steps to print a Nozzle Check pattern:
1. Turn the printer on and make sure paper is loaded into the sheet feeder.
2. On your i9900, press and hold the RESUME button until the printer light blinks twice. When you release the button, the Nozzle Check pattern will be printed.
3. After the Nozzle Check pattern is printed, compare the results to the example that has been attached to this message.
Please let us know the results of these tests.
If you need additional assiistance, please contact us at 1-800-OK-CANON.
11-06-2013 09:49 PM
cartridges are in the correct order. Still no change. Ran nozzle test and deep clean - same story.
11-06-2013 10:08 PM
