09-28-2016 09:00 PM
I'm using a canon MG2520. Trying to scan one page
10-31-2016 06:14 AM
Hi bjwillingham,
There is a program that comes with the printer called the IJ Scan Utility that can assist you with scanning documents in and saving them into your computer. To scan using the IJ Scan Utility, please follow these steps:
1. Place the first page of the document you would like to scan on the platen glass of the printer.
2. Start IJ Scan Utility.
2-1. If using a Mac: Go to the GO menu of Finder, select APPLICATIONS, then double-click the CANON UTILITIES folder, IJ SCAN UTILITY folder, then CANON IJ SCAN UTILITY icon to start IJ Scan Utility.
2-2. If using a Windows computer: Go to your START menu, then select ALL PROGRAMS (or ALL APPS if Windows 10), then CANON UTILITIES, then IJ SCAN UTILITY (folder), then IJ SCAN UTILITY (program).
3. In the Canon IJ Scan Utility window that opens, click SETTINGS.... in the bottom right of the window. The Settings dialog box appears.
4. Click the DOCUMENT SCAN option on the left pane of the window, then set the item size, resolution, etc. as required.
5. In the SAVE SETTINGS section of the window, you will select the save format and location of the document you are about to scan.
a.) In the FILE NAME field, specify the name you would like to give the file. By default the filename will begin with IMG; you can remove IMG and change it to whatever you would like to name the file.
b.) In the DATA FORMAT field, use the drop-down arrow to select the desired option. If you are scanning a multi-page document, select the PDF (Multiple Pages) option. Note: If you are scanning photos, you will have the option of scanning items as JPEG, TIFF or PNG format.
c.) In the SAVE IN field, please navigate to the area where you would like the file to be saved once it is scanned in. By default, the file will be saved in the MY DOCUMENTS folder.
6. Once all settings have been selected, click the OK button at the bottom of the SETTINGS (DOCUMENT SCAN) window. The IJ Scan Utility main screen appears.
7. Click the DOCUMENT button. Scanning starts. Click the CANCEL button to cancel scanning if needed. Scanned images are saved in previously selected folder location specified in the SETTINGS... window.
Please note that if you want to scan photos, you would follow the steps above, except for instead of selecting the DOCUMENT SCAN option, you would select the PHOTO SCAN option in step 4, and you would click on the PHOTO button in step 7 instead of the DOCUMENT button.
Once the items above are set for document or photo scanning, in the future, you will only need to launch the IJ Scan Utility, then press either the DOCUMENT or PHOTO button to perform the scan (unless you want to make changes to the settings).
Hope this helps!
12-13-2016 10:02 AM
12-13-2016 10:39 AM
Hello Happyhi!
To have a better understanding of your issue, please let everyone know what printer and operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at usa.canon.com/support or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
