09-25-2016 10:19 AM - edited 09-25-2016 05:54 PM
Some time ago, on default print quality settings, the black would go a bit faint on the last few lines of a full page of text. If there were more pages, each would start out fine but have the same poor quality near each page bottom. I changed quality setting from standard to high & the problem seemed fixed. Just the past several days that poor quality near the bottom of pages showed up. Today the black will not print at all. I did 2-3 deep cleanings with a fresh cartridge, but still no black. Colors print just fine. Do I need to replace the print head?
09-27-2016 08:37 AM
Hi PMHilton,
Since the black ink is no longer printing, and replacing the ink tank and performing the deep cleanings did not resolve the issue, the printer may require servicing. We ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) for further assistance. A Canon technical support representative will be happy to help. There is no charge for this call.
09-28-2016 04:34 PM
Removing the ink tanks & placing the print head in a shallow dish of Windex for 2-3 hours led to a nozzle check test that was sharp as a tack, black included.
09-27-2016 08:37 AM
Hi PMHilton,
09-28-2016 04:34 PM
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
