04-26-2013 10:40 AM
04-26-2013 10:52 AM
Hi kbswearin!
So that the Community can help you better, we will need to know exactly what equipment you're using, any error messages you're getting, and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x). Any other details you'd like to give will only help the Community better understand your issue! Thanks and have a great day!
01-10-2014 04:37 PM
I'm having the same problem with my Canon Pixma MX410
01-18-2014 06:15 PM
Hello Fishbj,
Specify the document and print it following the procedure below.
1. Make sure that the machine is turned on.
2. Load paper.
3. Press the FAX button.
The Fax standby screen is displayed.
4. Press the Menu button.
The Fax settings screen is displayed..
5. Use the
button to select Memory reference, then press the OK button.
6. Use the
button to select Print specified doc., then press the OK button.
The document selection screen is displayed.
03-29-2018 01:55 PM - edited 03-29-2018 01:55 PM
Hello,
I followed these steps and it DID resolve the problem however, steps 4 - 6 were not possible until I turned my machine off and back on again. If you're still having trouble, you might try a restart.
