Canon MX 459 fax printing...
I have a Canon MX459 and all received faxes go straight to memory instead of printing when they are received. Does anyone know what setting I need to change in order to have faxes print when they are received?Thank you!
How do you print envelopes from your computer? Never got a user manual for my Pixma Mg 5520. Thanks
I replaced both black ink cartridges, which were low. That did not help. I then cleaned the print heads and did an automatic print head alignment. I got an error message indicating the automatic alignment did not work properly. When I tried manual pr...
I have windows 8.1 and I try to scan something, it sais I need a WIA driver to use this device.Then I try to find the driver and there is absolutely no label on the printer except Canon and Pixma.Device manager sais its MG 2100 series, on the interne...
Please let me know how to set up my ImageClass 4770 wireless? I'm a lo tech person but need to set it up to use Vonage box in my bedroom where it's hardwired to my modem and yet use the 4770 to scan in docs to my computer in the office down the hall....
I have done the print the page and scan adjustment three or four times to no avail. When I go to my control panel under printer and print test page it is perfect. Then try to print something on line and it is blurred. Help plz.
I keep getting error message 6001. I followed the instructions for that error code. No benefit. Help me. I need my printer to work!
I am unable to accurately follow the MX432 directions related to aligning ink heads. I have tried to follow the Canon directions that are on-line and available with my printer, but the directions are not very well-written. I seem to be printing alig...
I have a canon MP730. I installed a new black ink cartridge. Now it won't print in black only color.
The MX922 printer is discovered. But I can't get to the system information to check status, etc. I'm sure I'm missing a step somewhere, but can't find an appropriate guide/manual.
what will be them problem if in middle of photocopy complete balnk is present thruoghout. IR 3750.ACTUALLY IT HAPPEN FROM SOME TIME.AS I PUT THE PAPER IN SECOND TRAY ND IN ltr POSITION.WHEN EVER I PRINT A COPY FEW INCHES FROM LEFT SIDE IN VERTICAL P...
how so i make my printer recognize the ink cartriges
My desktop PC (Windows XP (SP3) and laptop (Vista) have both stopped "seeing" my iP4950, telling me that it is "offline". The printer is correctly connected and switched on. I have tried two different USB leads and I have tried to re-install the driv...
Our MX472 printer is about 2 months old. We had a paper jam yesterday and removed the paper. It was torn, but we believe we removed all pieces. We inspected it from the front and the rear, and could not find anymore traces of paper. Unfortunately, it...
| Subject | Author | Posted |
| 08-26-2026 11:26 AM | ||
| 08-24-2026 06:04 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM |
