03-11-2016 05:29 PM
Just got a new Win 10 computer. Didn't have to do anything for my MX 922 printer and fax to show up in Printers and Devices - great. But when I tried to scan from the MX 922 control panel, it said "Set the PC to start scanning" I then realized that, while I went through the machines settings to recognize my LAN settings, I can't figure out how to change the option at the top, which currently reads "PC / Local (USB)" to the proper LAN setting.
Anyone know how to do this?
03-12-2016 11:10 AM
Update...
I found my original (Windows 7) installation CD. I went through the installation process, but I keep getting an error message "Canon IJ Driver Installer has stopped working". I think it's the IJ Driver that will set up scanning for me. I've been through the setup screens on the printer to "Change wireless/wired", but still my only scan option is to "PC/Local (USB)". And I don't have a USB plugged in - I have ethernet plugged in. I printed the Network Configuration Page, and it says that both Wireless LAN and Wired Lan are inactive. I tried to Reset LAN settings. I tried Confirm LAN settings, and it shows that the connection is Active.
Help!?!
03-14-2016 07:54 AM - edited 03-14-2016 07:55 AM
Hi ericbro,
Uninstalling the network port and printer driver and reinstalling them will resolve this issue. To do this, please follow these steps:
1. Put the PIXMA MX922's CDROM in the CDROM drive. If the welcome screen appears, exit it.
2. Click on Start and then All Apps.
3. Click on Windows System.
4. Click on RUN.
5. Click Browse. In the Browse window, click on the CANON_IJ CDROM.
6. Double click the folder named WIN.
7. Double click the folder named Driver.
8. Double click the folder named DrvSetup.
9. Double click the file named DELDRV. If you are using the 64 bit version of Windows 10, please double click DELDRV64.
10. In the Run box click OK and follow the on-screen prompts to remove the driver.
Once complete, please follow these steps:
1. Click on Start and then All Apps.
2. Click on Windows System.
3. Click on RUN.
4. Click Browse. In the Browse window, click on the CANON_IJ CDROM.
5. Double click the folder named WIN.
6. Double click the folder named Driver.
7. Double click the folder named LAN.
8. Double click the file named CNMNPU.exe
9. In the Run box click OK.
10. Follow the prompts to uninstall.
Once complete, restart the computer.
To install the unit for use over your network wirelessly, please follow these steps when the computer restarts:
1. Press the <Menu> button on your PIXMA MX922.
2. Select Setup and press the <OK> button.
3. Select Device settings and press <OK>.
4. Select LAN settings and press <OK>.
Select the type of network connection you are using and then follow the on screen prompts to complete the setup.
Next, please download the latest driver for your PIXMA MX922:
1. Visit Canon's website at: http://usa.canon.com/support
2. Type PIXMA MX922 in the "Enter a Model Name" box and click the Get Drivers & Downloads button.
3. In the Drivers & Downloads section, please click Drivers.
4. Click the Select button next to the MX920 MP Drivers.
5. If you agree, please select the checkbox next to "I have read and agree to the terms of the Disclaimer and wish to continue with the download".
6. Click the Download button.
7. When the Save As box comes up, click Save.
8. Once the download is complete, open your Downloads folder.
9. Double click [mp68-win-mx920-1_00-ejs.exe]. Files will extract.
Follow the prompts and the installation will complete.
To view a walk-through of the installation process, please use the following link:
http://downloads.canon.com/html/wireless/modules/14slw-ww/14slw-ww-0010-000/14slw-ww-0010-000.html
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
03-17-2016 01:49 PM
I'm using a PIXMA MX479 and these instructions didn't work.
07-09-2018 02:40 PM
