02-02-2024 08:35 AM
It is not identified in the 472 page manual, or anywhere else that I can find. (Nor, does it seem to serve any obvious purpose.)canon part.jpg
02-13-2024 09:18 AM
It looks like the rear feed listed as letter C in the parts list HERE.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as
02-13-2024 09:28 AM
I don't think that picture shows the part I am referring to as being labeled, even. It is the spring loaded piece that is in front of the "rear feed". It folds down when you close the paper support "A".
02-13-2024 09:45 AM - edited 02-13-2024 09:52 AM
I think I found it. See page 73 of the user guide.
G3070ser_OnlineManual_Win_Mac_EN_V01.pdf (c-wss.com)
It states its there to help keep long paper from rising and becoming mis-aligned.
02-13-2024 10:07 AM
"Check that the tip of paper comes up against the inner part of a feed slot when you load
long-length paper. Depending on the weight of the paper, the leading edge may rise and printing
may be shifted. Make sure that the leading edge of the paper does not rise, such as by holding
the part that protrudes from the rear tray."
The manual doesn't actually identify the part I am referring to and I don't see how it could possibly do what this quote claims, as the part never contacts the paper, at least with 11" paper and I don't have any longer paper to try. (The diagram on page 74 shows how long paper would work.) Thanks for your answer, though!
02-13-2024 10:42 AM
I recommend you contact Support. I'm sure they can give you an answer. Its important to register your printer as well.
02-13-2024 10:57 AM
Thank you for reminding me to register the printer.
