11-15-2025
04:07 PM
08:21 AM
James_C
I can print documents, but unable to print photos (“Unable to communicate with printer” show up). Printer is new, so should not be a need to realign.
11-15-2025 05:20 PM - edited 11-15-2025 05:22 PM
We are going to need more information in order to provide assistance.
What is the operating system version and build you are using the printer with?
How is your printer connected and to what?
What software drivers, applications and/or installers did you run when you installed the printer?
What type of image file are you trying to print. Have you tried to print more than one type or file?
What media type are you printing on. plain paper, photo paper etc?
Have you tried printing from more than one application or program?
11-15-2025 05:39 PM - edited 11-15-2025 05:40 PM
First off use a usb connection to check photo printing issues.
Driver Issues: Ensure that the correct printer driver is installed. Using a driver for a different printer can cause communication errors.
Connection Problems: Check if the printer is properly connected to your computer. If using a USB cable, ensure it is securely connected. For network connections, verify that the printer is set up correctly on the network.
Large File Sizes: Printing high-resolution photos can lead to delays or errors. If the file size is large, consider reducing the resolution before printing.
Check Printer Status:
Verify Paper Settings:
Restart Devices:
Delete Print Jobs:
Use Diagnostic Tools:
Following these steps should help resolve the communication error when printing photos with your Canon TR8620a printer.
