12-01-2021 07:54 AM
Common Wireless Communication Issues and Steps to Troubleshoot Them
There are many reasons that your printer may be indicated as being "offline" or "not responding". Basically, the printer and computer are not able to communicate. Since there are multiple causes for these messages, there are also multiple possible resolutions. The steps below will help in resolving the issue and possibly identify the cause.
Verify Power
Select the Appropriate Printer
Restart the Printer
In some cases it may be necessary to power cycle the printer to potentially reset any error conditions or lost communication.
Reboot Your Router / Modem
If your router and/or modem is not able to communicate with devices that are usually connected, you should power cycle the router.
Reboot Your Computer
In some cases, it may be necessary to restart your computer to refresh connections with the various peripherals such as routers, modems, printers, etc.
Reinstall the Printer Driver
02-08-2022 04:57 PM
To all. Canon over the phone helped me to resolve problem.
After doing all the above maneuvers without result, agent tested I try a different browser and... all worked fine. My Chrome browser had been corrupted. So: Uninstalled Chrome, then reinstalled, and computer connects to printer fine and prints all aspects properly now.
04-01-2022 02:34 PM
Lots of hours wasted. My router does not reboot fast enough for the printer wireless setup timeout. Tried using USB to setup wireless but it ends up asking for my Admin password. I cannot think of any reason for this other than it gives Canon and its individual employees unrestricted access to my computer. I have tried calling customer service but got the message to call back later. I have like the various Canon printers for many years, but this experience tells me I have made a mistake and need to send this printer back.
06-30-2022 10:06 AM
My problem started with the new router. I tried unplugging/repluging everything possible. No good. Did the above and reinstalled the driver. No good. Realizing the drivers were for the older Mac OSs, I finally found
That did the trick.
08-26-2022 09:31 AM
What number did you call? I can't find one for my PIXMA printer.
08-26-2022 09:44 AM
You can reach technical support at: 1-800-652-2666 and find additional support options HERE
08-26-2022 10:36 AM
Thanks so much! I'll give it a try.
09-04-2022 08:06 PM
I am new and I cannot find the place for asking questions. It's about my TS9521C printer. Can someone direct me an "ask question" page?
09-06-2022 02:46 PM
Hi pslane1,
Please use this link:
https://community.usa.canon.com/t5/Desktop-Inkjet-Printers/bd-p/desktopinkjetprinters
On the page that loads, please click on the "Start a Conversation" button.
09-13-2022 05:38 PM
Found canon Pixma printer problem. My new router interface (sagemcom 8566w) interface was set to accept only WPA2/WPA3 + AES encryption protocol. When set back to only WPA2+AES it WORKED. Problem: old printer, new T Mobile router.
