12-24-2023 11:25 AM - edited 12-24-2023 11:27 AM
I'm having an issue with my rear paper tray that is making my TS9520 essentially an expensive paperweight right now. This is incredibly frustrating. I was in the middle of a print job when suddenly the printer told me I have a "no paper in the rear tray" error despite there being plenty of paper in there. I can also physically SEE that the paper doesn't even begin to move down into the paper feeder. I've tried:
-Shining a light to make sure I don't see anything stuck on/in the rollers. Don't see anything.
-Putting more or less paper in the feeder.
-Putting different size paper in the feeder.
Nothing works. I hear the rollers rolling but nothing "catches" so to speak.
HOWEVER, when I run the "clean paper rollers" maintenance cycle, the rear tray grabs the paper with zero issues. The second I go back to trying to print anything though the rollers go back to not gripping. The paper I use for the "clean rollers" cycle is the exact same paper I'm using to print on.
If ANYONE could help I would appreciate it greatly, I'm at a loss!
01-08-2024 08:16 AM
What version of Windows or MacOS is the printer installed on?
01-08-2024 06:00 PM
It's running on Mac Sonoma 14.1.2.
05-16-2026 04:35 PM
I am having the same problem. Was your problem ever resolved?
05-17-2026 03:28 PM - edited 05-17-2026 03:29 PM
Clean paper rollers program applies more pressure on the rollers. So if the cleaning program feeds the paper, but paper will not feed when printing, then you may need to clean the rollers using the program a couple of times and if that does not fix it then manually with a cotton swab or paper towel, some alcohol, and hand clean the rollers while spinning them.
