10-07-2018 02:30 PM
GREETINGS.
I am using macOS 10.14 to print a borderless 4x6 onto Plus Glossy II paper using my TS9120 with the latest over-the-air firmware downloaded to my printer.
The image data are stored in a JPG at 300 dpi. I have also tried printing the same image data from a PDF. The problem that I describe below seems to not depend on file format.
In my print settings, I have "Paper Size" set to "4 x 6 Borderless," "Feed from" set to "Rear Tray," "Media Type" set to "Photo," and "Quality" set to "Best."
The problem that I am having is that the image information does not scale properly on printout. On the printer dialogue, when I set "Scale" to 100%, the image is stretched out from the bottom right corner by about 3%. (In landscape orientation, the bottom right corner of the photo paper in the rear tray points behind and toward the right of the "A" in "PIXMA" on the top cover of the printer.) The result is that the bottom short edge of the printed photo is missing the true image data. The print along the bottom short edge has been replaced by the image data from a few pixels higher up on the photo and stretched to the bottom edge and slightly to the right.
I have tried to correct for this by scaling the image in the print settings from 100% back to 97%. This does not fully undo the stretching, but is still better than at 100%. However, if I try to go lower (e.g., 96.5%), then a white border appears along the *opposite* short edge of the photo.
I never used to have these problems when I had my MG7720, which Canon agreed to replace.
What's going on? How do I get my 4 x 6 borderless prints to scale correctly?
11-08-2018 09:28 PM - last edited on 11-08-2018 09:31 PM by SamanthaW
Hi andrejfavia,
For the issue being experienced, it is recommended that you Contact Us for further assistance. In the interim, information regarding performing borderless printing can be viewed here.
11-21-2018 04:22 PM - edited 11-21-2018 04:49 PM
Ramona, I just called Canon earlier today through the tele number that is on the Contact Us page concerning my printer.
After an hour and a half over the phone, the higher up told the rep who I spoke with to tell me, that the printer overlaps some picture information outside of the printed area, and is, according to what the technician was told, "within the specs of the machine."
That resolution is not acceptable.
For a professional photo company to say that a misaligned 4x6 borderless print is *SUPPOSED* to print incorrectly (as I showed in my test image on page 1) is ludicrous, and therefore, I consider this printer defective.
Furthermore, for a Canon rep to say to the rep to tell me that's just how it is and they won't do anything about it is even more outrageous, and again, not acceptable.
01-14-2019 02:54 PM
I have the same problem on my just-purchased TR8520. Spent two hours with tech support and came up with the best(?) solution.
4x6 borderless with 4x6 image. With borderless the printer makes the image larger by close to a quarter inch all the way around I think. And it's not exactly the same on all sides.
I do this:
1. Be sure the internal size of the image (you can set that in Photoshop), is 6x4.
2. Specify a scale factor of 95% when printing from Preview.* It's almost exactly on two sides and slightly truncated on the other two. When I try to print from "Photos," there is no option to specify scale.
* I'm on a Mac.
It's not perfect but way closer than the default.
Might be different on your printer.
Good luck.
03-02-2019 09:11 PM
Well WilburBruce (and others), if it's happening on TWO printers, and Canon STILL hasn't fixed this problem on my year-old TS9120, then it might as well be happening on all of their new inkjet printers.
Canon so far to date has failed to inform me that they have any fix for the issue (which now both you and I describe).
Most frustrating to me is the ~$20 or so of ink that I wasted in trying to troubleshoot this issue.
Canon's over-the-phone apology back on November 21, 2018 for making me go through that much ink is not a suitable amendment for my ink expense. I do not agree to spend money on replacement ink, which is already an outrageous expense given the prices that I looked up.
For the time being, my printer will continue to collect dust and carry empty ink cartridges, not to be replaced, except through a company reimbursement. (And note that I said reimbursement, not "Here's 20% off your purchase through Canon.com" - none of that nonsense, I won't buy it.)
