TS8220 Can't Change Paper Source
CanonMad
Working on a Mac.     After printing a photo using (photo paper in) the Rear Tray, the TS8220 will not go back to using the cassette.  Keeps erroring and will not allow me to change back to the (front) cassette as the default.
Yes, I did unplug power to the printer for 3 minutes then re-started.  Still not working & there's nothing on these message boards that covers this.
Blah blah blah
1 REPLY 1
Patrick
Hi CanonMad,
Please try setting the rear feed to 4" x 6", so when you print from your computer on letter sized paper, the printer will default to the cassette.
To do this, please follow these steps:
1.  Turn you PIXMA TS8220 on.
2.  Tap the gear icon at the bottom of your printer's display.  Patrick_0-1741964281959.jpegPatrick_0-1741964281959.jpeg
3.  Tap Feed settings.  Patrick_1-1741964281900.jpegPatrick_1-1741964281900.jpeg
4.  Tap Rear tray paper settings.
5.  Tap the Change button.
6.  Select KG/4"x6"(10x15) from the list.
7. Choose Pro Platinum, or any type of paper.
8.  Tap Yes.
9.  Tap the Home icon in the upper left corner.
Once set, please attempt to print.
Friends and Family
