TS7720 - 2 sided documents always prints from rear cassette
DRAE
I have just purchased a TS7720 and trying to print a 2 sided document.   I select 2 sided, but the printer continues to print from the rear tray, which does not work!  I cannot get it to do it correctly.   I am getting fed up and about ready to return.   I never had this problem with my TS9120.
3 REPLIES 3
Sorry to hear of your issue.  Merely selecting 2 sided printing does not tell the printer which paper source to use.  The printer supports duplex printing from either source allowing you to print 2 sided using different paper sizes.
What is the version and build of your OS?  Are you running Windows or MAC?
How is the printer connected?
Important: Have you installed the printer drivers?
Paper Settings - TS7720 https://share.google/35rB4bHW9wQTgGFPb
Note that settings in the printer driver can also affect paper handling and printing behavior.
bridgesc
I too am having trouble printing 2 sided documents. I have installed the drives. My printer TS 7720 has printed two sided documents for at least a year. It stopped printing 2 sided documents. very frustrating. I cannot figure out how to get it to work.  So far, nothing I have tried works.
