11-15-2023 11:54 AM
Everything else looks like it prints just fine, normal. Only PDF files prints double making it look blurry or out of focus. It used to print just fine then all of a sudden it started doing this. I'm wondering if it did an update of some kind back a few months ago could cause this? Is there anyway to put back the original hardware software/firmware in this printer?
11-16-2023 10:39 PM
11-16-2023 09:54 PM
I have done that several times but I do not have a problem doing it again.
11-16-2023 10:28 PM
I did the print head alignment, still double/blurry with PDF and word documents
11-16-2023 10:32 PM
I did try printing a picture with word and it did the same thing, double/blurry
11-16-2023 10:39 PM
You can set: black only
Or repair the printer
11-16-2023 10:54 PM
It printed perfect.
11-16-2023 11:22 PM
Just on a whim, I did a print with color only and it printed perfect.
11-16-2023 11:34 PM
The main reason is still the inaccurate color matching of black and color.
So, both black and color only can solve this problem.
This is a very strange problem, I have never encountered such a serious color mismatch before.
11-16-2023 11:47 PM
You guys think it is a physical hardware problem and not a software problem. What would make this start doing this all of a sudden? Do you think something shifted inside the printer? I hope you guys come up with a solution because this printer is just about useless to me as it is.
11-18-2023 04:39 AM
Have you guys at Canon come up with any solutions. I'd like to get this resolved. I hope your discussing this problem with someone there at Canon so we can get this resolved/ Thank you.
11-19-2023 11:35 PM
Sorry, I'm just a Canon printer user, not a Canon staff member
To solve this problem, it is likely that the print head needs to be replaced
