TS6420a prints double vision blurry only PDF files
rclark041
Everything else looks like it prints just fine, normal. Only PDF files prints double making it look blurry or out of focus. It used to print just fine then all of a sudden it started doing this. I'm wondering if it did an update of some kind back a few months ago could cause this? Is there anyway to put back the original hardware software/firmware in this printer?
You can set: black only
Or repair the printer
19 REPLIES 19
Stephen
Moderator
Moderator
Hello there!
So we have a complete picture, it's helpful to know the following:
Which version of Windows or macOS are you using?
Do you connect to your printer using a USB cable or WiFi?
Are the most up-to-date software/drivers installed from the Canon USA site HERE?
If you have any other details, feel free to let us know!
windows 11, wifi, and I'm not sure
WILLIM
Enthusiast
Can you provide blurry images for printing
You can try toperform print head alignment on you printer.
I have done print head alignment several times. Here is what it looks like when it prints.20231115_224322.jpg
This malfunction is too strange.
I feel that black and color are not overprinted together.
I would like to confirm if there is a problem with double-sided printing when printing a document in Word software doc format?
Can you test the printing effect by setting it to gray printing?
You can select preview before printing in the driver.
Check if the preview before printing also has this issue.
Ok, let me see if I can keep this straight.
PDF grayscale double/blurry
PDF double sided double/blurry
word docx double/blurry
word docx grayscale looks ok
word doc 2 sided double/blurry both sides
word 2 sided grayscale double/blurry both sides
The preview looks good.
Based on the information currently provided, I believe it is likely a hardware issue with the printer.
You can try to perform the print head alignment operation
