TS6320 paper loading issues
jtwind
Printer worked fine for the first 3-4 months.  Loaded some new paper in the tray, same paper I've always used and it says the tray only takes plain paper?  When I do it get to print it folks over the top right corner of the document.  Have tried different amounts of paper being careful of how it's loaded and the guides are adjusted buy nothing helps.  Any ideas?  Thank
1 REPLY 1
Patrick
Hi jtwind,
Because there may be a hardware issue causing the paper feed issue, it is recommended that you contact one of Canon's Technical Support Representatives via phone. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
