04-02-2019 11:58 AM
Brand new TR8520 multi-function print/copy/scan/fax won't copy from the ADF. I've tried everything from the manual - at least I think I have - and it's still not working. Help!
04-08-2019 04:14 PM
Hi Ahenryplotts,
So we can best assist you, we would need some more information to help narrow down this issue.
If this is a time sensitive matter, please contact Canon at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST.
09-03-2019 06:58 PM - edited 09-03-2019 07:02 PM
Having a similar issue.
2 year old TR8520 multi-function print/copy/scan/fax doesn't feed paper from the ADF.
When I put the paper into the ADF, I don't hear a beep.
My guides are properly set.
Please advise what to do?
Regards
09-06-2019 01:14 PM
Hi user10166,
Please follow the steps on the following page to load paper in the ADF of your PIXMA TR8520:
https://ugp01.c-ij.com/ij/webmanual/Manual/All/TR8500%20series/EN/UG/ug_l_03_03_c.html
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
06-17-2021 11:16 PM
I am totally upset. I bought this printer from Target about a year ago. I thought it was upsetting when I realized two months after I purchased it that you stopped making ink for it, but recently I have had to fax, but I can't. NO MATTER WHAT I DO there is something wrong with you ADF and it won't fax. It says it's jammed, but it's not jammed. I know how to work printers and faxes. This is something that is wrong from Canon end. I am totally at my witts end! I have feeling you KNOW THERE WAS A PROBLEM AND STOPPED PRODUCTION TO THE POINT OF EVEN INK. I trust your product. I have many products made by you. WHAT IS GOING ON WITH THE ADF portion of your multi purpose printer/scanner/copier/Fax. Every other part of this machine works fine... BUT YOU CAN'T FAX!
