10-25-2020 04:38 PM
I am unable to copy a Black and White Document. I place the document on the platen, press the black button and a blank piece of paper is ejected.
10-27-2020 09:20 AM
Hi, laoszak!
So that the Community can help you better, please let us know if you're getting the same results when you try to print from a computer or mobile device. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
10-27-2020 05:10 PM
I CAN print a document from the PC and it will also scan a document. It just doesnt print from the platen.
10-30-2020 11:34 AM
Any solution to why I cannot print a copy from the platen? I can print from the PC.
12-02-2020 02:35 PM
Hi laoszak,
Please perform this test:
1. Tap the gear icon at the bottom of the display of your PIXMA TR7520.
2. Tap Maintenance.
3. Tap Print nozzle check pattern.
4. Tap Yes.
A test page will print.
Please compare yours to the example below. Does yours match the example?
