07-08-2015 09:04 PM
07-08-2015 09:24 PM
Hello wiseguy!
To have a better understanding of your issue, please let everyone know what model printer you are using (PIXMA MX922, MG6420, CP910, etc.), what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using, and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
07-09-2015 11:15 AM
Shanna,
My printer is a PIXMA MP560. I just started Windows 7 a few months ago, coming from an XP. I am anything but tech savy. Found an interesting note from Louielouie who said it was a piece of paper stuck on the ink cartridge. Didn't work for me. Sorry I can't spoend too much time this AM because I have to go for chemotherapy. But I will work on this every chance I get.
Thanks for your kindness.
Beth Wiseman
My printer says it is connected by both USB and WiFi but we think it is really USB. Another mystery.
07-11-2015 09:15 AM
Hello.
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-221BK
CLI-221M
CLI-221Y
PGI-220PGBK
CLI-221C
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MP560 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Settings and press <OK>.
3. Press <OK> on Maintenance.
4. Press <OK> on Nozzle Check Pattern.
5. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to this message. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
4. Press <OK> on Cleaning.
After a few cleanings, please print another Nozzle Check.
If the issue persists, please contact our support group using the "Contact Us" link below for additional assistance.
