Since I registered in a paper program. Will I automatically get sent in paper? When do
Shellee69
The printer needs to be powered on regularly in order to comunicate with the print plan servers.  Inks will be sent as needed in accordance to the plan you have subscribed to.
4 REPLIES 4
Moderator
Moderator
Thanks for joining the conversation, Shellee69!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Is it possible you are referring to the Canon Print Plan?
Canon PIXMA Print Plan | Canon U.S.A., Inc.
Yes the one for 6.99
