Scan multiple copies on one Scan To Folder Job
mbfromit
Can you scan once and have the job generate multiple pdf files in a Scan to Folder process.
This would be much like choosing to print 5 copies of one document, but in this case you would scan the doc once, and 5 identical pdf files show up in the scan to folder  ( using the Address Book entry )
4 REPLIES 4
Porcha
Rising Star
Hello mbfromit,
Welcome to the Canon Forum! For the community to better assist you could please provide the following information:
1. Model of printer
2. Operating System
3. The connection method of device
Model# iR-ADV C5535
Not sure what is meant by OS
Conection method is Ethernet
Hi, mbfromit!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
As far as Scanning once and having multiple pages in a single Scan operation available, the answer is yes.
However, you are not able to initate a single scan and generate multiple (identical) copies.  Each time the Scan operation is initated, only one operation can be completed.  Like, scan to File, or Scan to Email (supports multiple recirpents).  This is not Canon specific.  Seems to be the way most printers behave in my experience.
Friends and Family
