Reset a MP600 with U052 error code
hlplacid
Hello. I'm unable to reset my printer that has an error code of U052. Is there a way to manually reset this printer, since I am unable to navigate to settings?
Thank you.
4 REPLIES 4
U052 error is found here:
Canon Knowledge Base - LCD error messages on MP600
This is an error with the Print Head.  If the steps provided do not resolve this issue, the printhead is damaged or has reached the end of its usable life.
Thank you.
I have tried those steps and it looks like I'll need new part(s).
I want to recycle this printer and need to reset it to factory default settings.
I am unable to do the reset since I cannot clear the error.
I'm looking for a way to reset this printer, without getting new parts to fix the print head issue and clear the error so I can access the main menu.
No need to reset anything.  The printer does not hold any personal information with the exception of wireless information or Scan to email if applicable.
No one is going to bother trying to extract information from your (malfunctioning) damaged device.  It will be scraped.
Its not like it has a hard drive with tax or banking information.  Just dump it.
Thank you. I was trying to follow guidance from Canon. Even though the unit has no hard drive or memory to wipe, it was recommended to reset to factory default settings.
If I can't reset, I will just recycle as is.
Cheers,
-Helga
