05-19-2013 05:02 PM
I'm having trouble with my Verizon fios and my new Canon MX 922 all-in-one printer. I cannot receive faxes. The faxes sent to me sounds like fax but it just beeps. When receiving a fax, I MUST pick up the handset at the printer in order for the fax machine to pick up and receive the fax. What's supposed to happen (on Telephone Priority mode) is the fax should pickup either when handset picked up, OR answering machine picks up. If I let the answering machine pick up I cannot receive faxes from the other telephones in the house all I hear is a constant beep. Then the fax does not answer and ends after the answering machine picks up. I have turned off call waiting and Verizon voicemail. Again the fax tone comes through but all I receive our beep tones and my fax machine does not pick up. It worked just fine on my previous Samsung printer.
Does anyone have any suggestions or help? Verizon says everything should work with their system including faxing.
12-17-2013 12:31 PM
Here's an update...
I moved the base station to my office and plugged it into the MX922. I used one of the free fax sites to test the setup. When it rang, I heard the fax service sending its tones, but the MX922 didn't pick up. I did manage to get it to work if I switched the MX922 "Manual/Auto Switch" setting to ON, but as luck would have it, as soon as I received the fax successfully, my son called in and the machine picked up.
So, it looks like whenever I'm expecting a fax, I'll have to set the Manual/Auto Switch to ON, then switch it back to OFF once the fax has been received. That isn't the solution I was hoping for. Has anyone gotten a better result?
12-17-2013 01:38 PM
12-17-2013 01:57 PM
What do you have your Manual/Auto switch set to?
12-17-2013 05:15 PM
01-08-2014 08:11 PM
03-01-2014 11:26 AM
I too have same issue.
I called Canon and support person informed me that you must either have a telepone handset or answer machine plugged directly into the printer (along with telephone line).
This printer does not have the capablity of "picking up the phone' on its own like other printer / fax machines.
You have to do it with a handset manually or let your answer machine pick up and then the printer will see that a fax is coming in.
The big problem I have is that my printer is not in a locatoin where I can run to it to answer a phone (just in case a fax is coming in) or a location where I want the answer machine to be. What about people that don't use answer machines and use vocie mail by Fios or ???. How are they suppose to receive faxes when they aren't home?
I asked for the "complaint" department as was told that they don't have one.
Last Canon I will every buy, cannot even take it back becasue Best Buy return policy!
01-04-2015 12:23 PM
08-16-2016 07:05 PM
I have hooked up the Fax as directed with the phone plugged into the back of the machine and another phone line running to the jack on the wall. The machine sends FAXES but cannot receive them. My previous PiXma (890) Fax worked on a different number from the telephone. I am perplexed. Can someone help me? Do I set this up as FAX only? or line shared with the telephone?
08-16-2016 07:09 PM - last edited on 08-16-2016 07:29 PM by John_B
I do not see "receiver: mode" on my MX 922? Nor do I see "user friendly" under advanced settings after setting tel priority mode..
Barbara
<personal information removed per forum policy>
08-17-2016 02:17 PM
I too will n o longer by canon printers because of this issue. They have done nothnig to remedy this. Like others have said what if the person is not home and a fax comes in?
I am closing this account and forum....
