11-20-2020 04:45 PM - last edited on 11-20-2020 04:47 PM by SamanthaW
I can not figure out how to submit a new question, so I am tagging onto this one.
My Pixma G4210 prints only in green.
I have filled the ink tanks with Canon ink
I have deep cleaned twice.
It stays green, even when trying to print documents in black.
Photos are abhorrent.
The Canon support site will not help; they indicate that this model, at 2 years old, is extinct and I have to get support from the website.
So here I am.
If I "sound" frustrated, well, I am.
If you can help, please do. Or I shall dump this printer in a landfill and buy a different brand.
11-25-2020 01:17 AM
I was able to get it to work. For others who have this problem- I did 4 deep cleans, to no avail. Then I did an ink flush, and that seems to have worked.
Thanks to all who tried to help.
11-20-2020 04:49 PM
What do you get when you print a nozzle check?
11-20-2020 09:13 PM
It does not look good.
Black vertical s OK
All others vertically are a lght turquoise.
Black horizontal lines of rectangles seem OK.
Blue horizontal lines seem OK
No pink at all
Yellow is barely discernible.
Thanks fo responding!
11-21-2020 07:55 AM - edited 11-21-2020 10:50 AM
Have you tried running a deep cleaning? (Sorry - I just re-read your earlier post)
You should give Canon a call at 1-800-OK-CANON.
11-25-2020 01:17 AM
06-05-2022 01:55 PM
I deleted it from my computer Then used Bluetooth to discover it. When it did it showed 2 Canons. I tried the 3nd one which had some extra numbers after it installed it and problem solved
06-05-2022 01:56 PM
It was the 2nd one sorry
07-14-2022 08:22 PM
What is an "ink flush?" How is that done?
11-20-2020 06:51 PM
My 2 year old Pixma G4210 printer/copier only prints in green. It is getting progressively darker. Much as I like the color green, this is horrible. It does not matter if I try to print a document in black and white, a photo in color or copy anything. It all turns out green.
I use Canon ink, and refilled to see if that would help. It did not help.
I deep cleaned 3 times to see if THAT would help; it did not help.
I aligned the print head (I know that wouldn't cause green, but I tried everything.)
Does anyone have any ideas how to fix this?
