11-28-2016 12:59 AM
What do these mean; Canon ip8700 series MP2, GL2, GL3, PT1, PT2 PT3, SG2/LU2, SG3/LU3. These all under printer profiles.
The profile for my printer, PIXMA ip8720 is not listed. I've been using Canon IJ Color Printer Profile 2005 which I don't think is right.Maybe the reason I've been getting magenta color casts on B&W prints. Does anyone know anything about this? I'm thinking the MP2 etc are paper types? Help.
11-30-2016 09:20 AM
Hi brassman,
ICC profiles for your printer are included for use with programs such as Adobe Photoshop. The profiles listed are for these specific papers:
MP2 is for Matte Finish with a custom quality setting of 2.
PR1 is for Photo Paper Pro with custom quality of 1.
PR2 is for Photo Paper Pro with a custom quality setting of 2.
SP1 is for Photo Paper Plus media Glossy with custom quality of 1.
SP2 is for Photo Paper Plus Glossy media with a custom Quality setting of 2.
Other papers are as follows:
PR is for Photo Paper Pro and Pro II
SP is for Photo Paper Plus Glossy
MP is for Matte Photo Paper
SG is for Photo Paper Plus Semi-gloss
GL is for Photo Paper Plus Glossy II
PT is for Pro Paper Pro Platinum
LU is for Luster paper
If you are not using Canon Paper, these profiles may not work for you.
In regards to the magenta cast, please follow these steps:
1. Turn your PIXMA iP8720 on and make sure paper is loaded into the sheet feeder.
2. Press and hold the RESUME button on your PIXMA iP8720 until the printer light blinks twice. When you release the button, the Nozzle Check pattern will be printed.
3. After the Nozzle Check pattern is printed, compare the results to the example that has been attached to the bottom of this post.
Does the Nozzle Check print correctly?
If not, please contact our support group using the following link:
http://Canon.us/ContactLI
12-02-2016 10:25 AM
Patrick,
The nozzle check sheet printed out with no problems - looks just like your example. Now what?
12-02-2016 12:59 PM
Depending on how you are printing and what paper you are using try the following.
1. if you are letting the printer manage color and are using canon paper just select the appropriate paper.
2. if you are letting the photo app manage color you will need to select the paper type in the driver and the correct paper profile in the printing application.
Patrick's message above gives you the link between paper type and ICC profile.
Let us know what application you are printing from and we can be more specific.
09-12-2019 09:09 AM
HI,
I am new to printing and I am looking for the right profile for the paper I now have. the printer I use is Pixma IP8750
You say GL is for Photo paper plus glossy II. In Affinity there is GL2 and GL3. Wich one do I choose?
LU is ok for Canon LU-101 pro luster photo paper 260 grams A4 (20 vel)? this also comes in 2 or 3. like; SG2/LU2 and SG3/LU3. Wich one do I take?
Does 2 or 3 say something about the grams?
Canon SG-201 photo paper plus semi-gloss 260 grams A4 (20 vel)--> SG2/LU2 or SG3/LU3?
Canon PT-101 photo paper pro platinum 300 grams A4 --> wich one? PT1,PT2 or PT3?
Canon PM-101 Premium Matte paper 210 g/m2 A4 (20 vel)--> MP2 ?
what do you mean with the costom quality settings of 1 or 2?
I hOpe you can help me out here!
TIA
Kim
09-12-2019 09:39 AM
09-12-2019 09:58 AM
Thank you for this quick answere!
and 1 being lowest quality? /?????
2 is the safest for now, Ill try that
09-12-2019 10:02 AM - edited 09-12-2019 10:10 AM
No. 1 is highest quality.
I can't directly paste the link becasue of forum rules. just replace "-dot-" with a period "."
09-12-2019 10:20 AM
I have another question about the magenta testprint. Can I do this once on regular paper or do I need to test that with every papertype and ICC?
09-12-2019 12:09 PM
The test print s just to see that your printer is working correctly and that your monitor is adjusted to look like the print.
As as long as you are happy with results you are all set.
