PIXMA iP8750 4" x 6" prints misaligned
eddietheone
Hi I have a Pixma ip 8750 printer. When trying to print out postcard prints ie 4" * 6" it prints on only half the paper. The effect is as if the paper went through the printer starting in the wrong place. The guides at the back both adjust correctly so I don't think that is the case. A4 and A 3 paper prints out correctly. As I seam to be able to set them up correctly and get prints OK it just leaves the small size all wrong. I assume it is a set up issue of some sort so if anyone can help me resolve it I will be grateful. Cheers Edward
2 REPLIES 2
DerrickL
Mentor
Mentor
This issue came up on the forums some time ago, and a solution was posted. You can see it here, I suggest you read the whole thread.
https://community.usa.canon.com/t5/Desktop-Inkjet-Printers/pixma-ip8720-4x6-photo-orientation-wrong/...
eddietheone
Many thanks for the reply. I think I have got it to print correctly on the postcard size now. Hopefully I will remember all this as I do not use that size very often but rocking and rolling for now. Cheers Edward
