‎05-31-2022 08:44 AM
Hello,
The printer is MX495.
I did not us it for a while and today, when I started it, it turns on and off each 5 seconds.
All the printer buttons are blocked, including the power button (I cannot turn it off from the power button).
While the printer is on, no matter if I open or not the front cover, the cartridge holder moves continuously left and right without stopping.
There is a single word displayed on the display: ”Canon”.
Can you help me with an advice to eliminate this problem?
Thank you.
‎06-09-2022 09:42 AM
I am also able to print from internet
‎06-09-2022 09:44 AM
I took mine offline as I read somewhere , it worked and works now back online! 🤷‍♀️ but I’m printing and happy as I’d just bought a whole bunch of ink!
‎06-09-2022 09:45 AM
Try taking it offline I unplugged my modem it rebooted itself and works fine now! Good luck
‎06-09-2022 12:09 PM
Hi sufagal66
I've got it all sorted now that Canon uk have given me the link to the website to upload the latest firmware fix. It took me a while but I managed in the end. I was looking for a cog on the printer forgot it was a screwdriver & pair of pliers that was the set up menu.
‎06-23-2022 07:07 AM
Change the energy settings from the control panel. Hope It will help.
‎11-27-2024 03:12 AM
Your Canon MX495 printer issue might be due to a hardware fault, firmware corruption, or a stuck mechanism. Try these steps:
If the issue persists, contact Canon support or a repair service. Avoid disassembly if the printer is under warranty.
