Printer cleans heads after each print
cal680
How do I stop the printer from cleaning the heads every time after printing? I saw something abouot this problem at one time but can not find it now. I think it is causing the heads to fail becasue they are cleaned to much and they start blurring the letters.
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon
equipment you are using. Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
cal680
Model MG3620. The printer does a head cleaning job after each print jobn is done. If it prints one page or a hundred, it cleans the heads after finished job. It started this after installing remanufactured cartridges. Put in new Canon OEM and still does it.
Friends and Family
