Print error on my Pixma TS9550
Jorgen
I get this strange pattern of error, which does not disappear after cleaning the nozzles several times. Any suggestions? IMG_6682.jpgIMG_6682.jpg
2 REPLIES 2
Greetings ,
This issue is typically caused by a clogged printhead or nozzles.  Misaligned printhead can also cause blank lines or streaks in printed text.
Sometimes it can take several cleanings to resolve this issue, and depending on the clog you can waste a lot of money on inks trying to solve the problem.
Here's an article on print head alignment.
Canon : Inkjet Manuals : TS9500 series : Aligning the Print Head Manually https://share.google/z4eQEgPPVz3exgbFQ
Here's an article on printhead cleaning and deep cleaning.
Canon : Inkjet Manuals : TS9500 series : Cleaning the Print Heads https://share.google/ANBKciiDYXMgzHqxD
DerrickL
That is one of the most obvious nozzle issues I have seen for one color. It should be cleared up with a nozzle deep cleaning, maybe one or two should do it.
Friends and Family
