Print Head cleaning leads to web page with privacy warning
Ladyholly
I followed the directions to go to Printer and scanners to Option Supplies and then clicked on show printer webpage.  When I click on that, what comes up is connection is not private and that it could be someone trying to steal either personal or financial data. Has that comes up for anyone else?
5 REPLIES 5
DerrickL
Normally when using Windows, and you want to perform print head cleaning you go to  settings printers and scanners select printer then printer properties, and choose the maintenance tab, where you will find all the cleaning options. This could change depending on the printer.
Thank you!
Moderator
Moderator
Thanks for joining the conversation, Ladyholly!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Greetings ,
This is completely normal. The printer's web server does not use SSL encryption by default  http vs. https
Do not be alarmed. It's fine.  See my attached image where it says not secure in the address bar.  😉
Thank you!! That’s what I was looking for!
