Pixma ts8222 error
Kwilkins87
Says it’s jammed but it’s not. I had to pull paper out of it because it did jam, but the sheet was in one piece. Nothing got left behind. I can’t get the stupid code off and it says to extend the tray. And I do but it doesn’t do anything.
2 REPLIES 2
Sometimes forcibly removing a jam can cause these types of issues.  Things become bent, mis-aligned, etc.  About all you can do is inspect the device and try to see if anything was damaged.
I'd check the knowlegde base for your specific error and see if additional information is avaialble.
Next step would be to contact Canon Support.
i keep getting these codes
5100 and then it goes to 7700
and it always says to pull out the tray 1259
Friends and Family
