04-21-2023 02:47 PM - edited 04-21-2023 03:22 PM
Since updating to Monterey 12.6.5 my computer says my printer is not responding. The printer says to confirm if I want to connect to a computer, but then says to follow the directions on the computer and there are no directions.
Edited to add more information - the computer and printer connect via Wi-Fi. I've unplugged the printer and replugged it in, disabled it from the Wi-Fi and then enabled it, replaced low inks, tried to see if there were any updates to the printer but not able to get to that place, (that's when I get the message to connect to the computer and it can't), deleted the printer from my computer using system preferences and then attempted to add it and it says an error occurred. Probably some more things too, but that's the general gist of things.
Due to the timing I'm guessing it might be the update to 12.6.5, and was wondering if anyone else had encountered that.
04-28-2023 09:10 AM
If you have a smart phone or tablet, please try downloading our free Canon print inkjet selphy app and let us know if the app can detect the printer. You will want to make sure the mobile device is connected to the same network you connected your printer to.
04-21-2023 02:55 PM
Hi, lindamh!
So that the Community can help you better, we need to know whether your computer and your printer are talking to each other via Wi-Fi or via a USB cable. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
04-21-2023 03:23 PM
Thank you for the suggestion. I've edited my initial post.
04-28-2023 09:10 AM
04-28-2023 09:52 AM
Thank you for your response. I did as you suggested and it worked fine, so then I tried my desktop and it also worked just fine. I'm not sure what went on here, but I'm just happy to be working again!
05-08-2023 07:54 PM
Looks like I'm back again . . . My iPad will connect to my printer, and will print from the iPad. For a while my desktop was also connecting to the printer and all was working fine. Now, the desktop can no longer find the computer and I'm back where I started again.
