07-24-2017 08:45 AM
11-21-2017 03:47 PM
Hi PV745,
Slow printing may indicate an issue with the network connection, so let's start there. You can print out the network settings by following the steps HERE
Much of the information will not be relevant, but the important things to look at are:
Is the connection active or inactive?
Does the SSID (network name) match the one the computer uses?
What is the signal strength?
What is the IPv4 IP address?
I look forward to your reply.
