05-06-2024 02:24 PM
I have a Pixma TR8620a printer. We have been having issues with printing from my laptop (Dell running Windows 11) and my wife's HP laptop (running Windows 10). Both machines won't print as the Canon SW reports printer off line. We have reset the wireless modem, both laptops and the printer.
I removed the printer from my laptop and tried to reinstall the SW. Install SW won't connect despite the fact that the printer says it is connected to the WIFI (59% signal strength). I've disabled the IPv6 as per recommendations in other posts. Install SW says "can't find any printers" and then when using the easy connect, it says connection failed.
We use Optimum Altice WIFI and are connecting to the non 5G version on both PCs and printer.
#TR8620a
05-06-2024 04:27 PM
Welcome to the Canon Community, 69ChevelleSS!
The most likely technical issue based off your description is your WIFI signal strength of 59%. Especially during the initial set-up, it would be helpful to move the printer closer to the router, if physically possible. Anytime signal strength is below 85% there can be issues such as delays in printing as precise data communication is key to successful results. Please let us know your results!
Thanks for reaching out!
05-07-2024 10:00 AM
Hi Mike,
Thanks VERY much for the reply. I tried moving the physical printer from the living room to the family room. The modem/router is in the family room and the printer was in a direct line and maybe 25 feet from the router. Laptop has no WIFI issues when accessing web sites. I tried to run the install / setup and the program came back and said it could not find any printers. Tried "easy connect" and it did find the printer. The program then said "setting up" and ran for several minutes and said "connection failed". Printer said "easy connect complete or successful". Signal strength is 84% and the printer says it is connected to the WIFI.
05-14-2024 09:15 AM
Still fighting this one. Spent an hour on the phone with Canon Tech support and they diagnosed the problem as coming from the router. Need to call the cable company and have them look at the router.
05-14-2024 10:18 AM
In these situations, you start by verifying basic connectivity.
Log into the router and look at the list of attached devices.
Verify the IP the router has assigned to the printer
Verify the IP of one of the PC's you are using on the network
Next, can you ping the printer's IP from a command prompt.
If you enter its IP into a browser, does its webserver display
This is the basis for communication.
If this fails, you need to determine what is keeping the devices from communicating. 3rd party anti-virus software is a common example.
~CarePaks Are Worth It
