09-28-2020 01:00 PM
I can print to my TR4520, but can't scan from it. When I try from the computer I get an error that it cannot communicate with scanner, and code 2,157,50. When I try to scan from the scanner, it says "please wait a while" and then goes back to the main menu.
I know the device is working because I literally printed something, signed it, and tried to scan it to send it back, and it won't scan. I'm following the instructions from the button in the scan utility, and have verified that my scanner is the one selected in the "scanner selection" window. All the cables are plugged in tightly. I don't know what else to try.
10-14-2020 03:05 PM - last edited on 10-14-2020 03:06 PM by Porcha
Hi JillyBean4179,
The 2,157,50 error is an indication that the security software installed on your computer is blocking the incoming communication from the scanner of your PIXMA TR4520. Please identify which security software suite that you have installed; McAfee, Norton, Webroot, TotalAV, etc. You can try temporarily disabling the security software to scan or contact the vendor for further assistance.
11-14-2020 10:39 PM
04-24-2021 04:53 PM
07-10-2021 06:38 PM
I have the same problem, but my error code is 5,157,69. Help please. I turned off the Windows Security Firewall, but that did not fix the problem.
07-11-2021 11:37 AM
Turned off Windows Firewall ... no change. Still no schmae.
08-25-2021 02:13 PM
Hi CSouthwick,
The 5,157,69 error is an indication that the driver needs to be reinstalled.
You can download the latest driver here:
08-25-2021 02:15 PM
Hi ddachtera,
There are two errors posted in this thread, 5,156,69 and 5,157,59. Which one are you experiencing?
Also, do you own the PIXMA TR4520? If not , what model do you have?
08-25-2021 04:37 PM
Downloaded new driver for Scanner. Did not work. Still get the same Error code.
11-23-2021 07:53 AM
